flexible variable
Vitalie
New Member
Hello,
I am a beginner in performance testing and I have one problem, I will be grateful for your help. I have in my script some variables (var1, var2, var3, ..) and i need to get in the Beanshell variables in form var "i" (for example if i = 2 get ("var2) if i = 4 get("var4" ))
how can i do it?
Thank you in advance
Best regards,
Vitalie
int var1 = 1;
int var2 = 2;
int var3 = 3;
for(int i=1;i<=3;i++)
if(i==1)
print("The value of variable is :" + var1 + "The value of i is:"+i );
vars.put("variable1",String.valueOf(var1));
else if(i==2)
print("The value of variable is :" + var2 + "The value of i is:"+i );
vars.put("variable2",String.valueOf(var2));
else if(i==2)
print("The value of variable is :" + var3 + "The value of i is:"+i );
vars.put("variable3",String.valueOf(var3));
