Guys, I have a problem where the dynamic...
  • Thread starter Boopathy Ramamurthy
B
Boopathy Ramamurthy
Guys, I have a problem where the dynamic values are getting captured in EXTRARES , how do i correlate this value. I was able to find this value from tree view in EXTRARES and i correlated it , but it doesn't work fine, can some one help me with this. Thanks!
Boopathy Ramamurthy - write separate web_custom_requests for EXTRARES and place those requests right after the primary request (which has EXTRARES recorded in it). After writing the separate web_custom_requests for EXTRARES, remove them from the primary request and try to add weg_reg_save_param function above that web_custom_request (EXTRARES) where you have found the dynamic value in Tree view. Please let me know if it helps. Please zip your script and upload here so that I can have a look into it.
Recording in URL mode will work.even you can try recording on win nt level.
Boopathiraj Maruthachalam: are you trying to record scripts for Flex ..... ...That was bit challenging for first time ..but URL based recording and few simple settings have helped me to pass through ...
Can one of you post the Steps for settings to do FLEX recording and corelation?
