Hi All... Need your help as I am scripting using Seibel Web...
I
Ifti Inamdar
Hi All... Need your help as I am scripting using Seibel Web Protocol..facing few correlation errors even after handling many dynamic values... Hoping for a positive reply.. Greg,Ifty
R u using inbuilt auto correlation rules and also specify whether its not replaying or failing after 1st iteration ? Also what error its throwing
you need to import the cor file to get the Autocorrelation enabled, you can get this file from your Admin team
Sure..requested for this file from admin, once I get it will revert you all...thank you...
I also working for the same but best way which is found is manual corr. for seibel.
Hi. When we use siebel Web protocol it will auto correlate all hard coded values and some static strings in Web pages and it will save in _row ids. In this case we need to replace all original values apart from server dynamic values
