Hi Group Members, I am badly trying to resolve...
B
Binaya Parhy
Hi Group Members, I am badly trying to resolve one LR issue. It 12.02 Community version. I am unable to compile any Java code in java user protocol. Plz only those who are using this protocol and this version please help. Have been pissed off trying too many options. So concrete help will be appreciated.
Can you please explain the issues in details? Steps for reproducing the problem and any errors you get (screenshots)? Quick hint: do you have JDK installed? Is its path specified in Runtime Settings ("Java VM" tab)?
Just open a new script script and solution for java user protocol, click on compile button, it will throw error
Like "Can not find java.exe, javac.exe, javai.dll etc. I have 64 bit machine, tried both X64 and X86 JDk, If you are able to compile it than let me know the java configuration. I will make the exact same config and try to resolve my issue thanks in advance
Notify: Found jdk version: 1.8.0. [MsgId: MMSG-22986] Warning: Classpath entry not found: c:\program files (x86)\java\jdk1.8.0_40\bin\jre\lib; [MsgId: MWAR-22986] classpath=C:\Users\hp\Documents\VuGen\Scripts\JavaVuser1\;c:\program files (x86)\hp\loadrunner\classes\srv;c:\program files (x86)\hp\loadrunner\classes;C:\Program Files (x86)\HP\LoadRunner\Classes.zip;C:\Users\hp\Downloads\com.ibm.mq.jar\com.ibm.mq.jar;;C:\Program Files (x86)\Java\jdk1.8.0_40\bin\jre\lib;;;c:\program files (x86)\hp\loadrunner\lib\xstream-1.3.jar;c:\program files (x86)\hp\loadrunner\lib\xpp3-1.1.4c.jar [MsgId: MMSG-22986] Path=C:\Program Files (x86)\HP\LoadRunner\Bin;C:\Program Files (x86)\HP\LoadRunner\Bin\tulip\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP\LoadRunner\classes;C:\Program Files (x86)\HP\LoadRunner\classes\srv;C:\Program Files (x86)\Java\jdk1.8.0_40\bin;C:\Program Files\Broadcom\Broadcom 802.11;;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Hewlett-Packard\SimplePass\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\HP\LoadRunner\strawberry-perl\perl\bin [MsgId: MMSG-22986] Notify: VM Params: . [MsgId: MMSG-22986] Java VM internal error:Error Loading javai.dll. . [MsgId: MERR-22995]
set the class path in environment variables and upload .jar's in runtime settings
Path: C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\HP\LoadRunner\classes;C:\Program Files (x86)\HP\LoadRunner\classes\srv;C:\Program Files (x86)\Java\jdk1.8.0_40\bin;C:\Program Files\Broadcom\Broadcom 802.11;;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files\Hewlett-Packard\SimplePass\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\HP\LoadRunner\strawberry-perl\perl\bin
have tried all these...@Ram Lekkala r u able to run java program in lr community 12.02???
can u tell me version of java X86 or X64, path variable and what u have given in runtime setting JVM SSs will be very help full my gmail id bparhy@gmail.com
im using the same lr version on windows 7. this issue looks like either you missed some dll's during installation or pointing wrong jdk version which is not compatable to lr.. im just assuming.. let me check...
Shane is right. Check it. Also remove the explicit "...\jre\lib" folder from your classpath. As the error message suggests, it is an invalid entry.
Dll i dont think i missed as i did the normal installtion. I will try the options and will let u know the result.
what is compatible to LR 1.8 update 40 the latest one I have downloaded. Please help. tomorrow I have to give an update to my Manager.
Igor Markov & Ram Lekkala Requesting to plz share screen shots of your Java VM, Classpath setting of LR and Path variable content along with any other variable like JAVA_HOME etc I need to create manually. I am downloading JDK from Oracle site.
