hi, i am using LR 12.50 for https native mobile app recording.i am...
Ashish Kate
hi, i am using LR 12.50 for https native mobile app recording.i am able to generate .pcap file but while importing pcap file into vugen for generating script its asking for server side certificate and private key which i do not have .can anybody help me in solving this issue ? i wanted to generate vugen script from that .pcap file.
In your script,Start with web_set_socket_options function
Why not just record it directly via proxy and avoid the certificate issue required to decode the pcap?
i am not able to generate single line of script due to server side certificate:(
james i am not able to record via proxy even though i am using same wifi network on mobile and laptop.traffic is not recorded at all after inserting proxy ip address of latop into mobile and using 8080 port..
If using ssl don't you need to import the proxy's ssl cert onto the phones trusted cert auth?
