Hi to all, I need few basics to be cleared...
Siva Thangavel
Hi to all, I need few basics to be cleared 1.how many vuser can a load generator handle min and max 2.what is the required ram and memory for the controller, analyser, vugen, , load generator if we need to run 1500vusers. 3.how many vugen, load generator, controller needed for running 1500 users and their requirements
1. Minimum 1. Maximum is determined by the resource fingerprint of your virtual users with 20% headroom on each of the finite resource pool elements. Short way of saying, "your mileage may vary." 2. The controller is lighter when compared to the other components, but it would be run on a dedicated host from the load generators. If we take some rule of thumb guidelines and make note that the controller is a 32 bit application and can address (as a result) at the most 4 gig of memory (2^32 address space), then I would recommend a minimum of 2GB for a healthy OS dedication and then the other 2GB for your application space. If you have a 62 bit OS and you are running your controller in the WOW32 address space then go head and give your host 8GB so you can tear out a full 4GB for the WOW32 subsystem when it starts or it it needed 3. There is a process question and a resource question embedded here. I look to a minimum of three load generators in any condition. Two are for primary load and one is for a control set, running a single virtual user of each type. All load generators are hardware matched. This is in addition to the controller node. So, you're looking at four nodes as a minimum test set, on a process basis. Having noted that, depending upon your virtual user type and your resource fingerprint for your virtual users, your load generation need could range anywhere from the three load generator minimal set to requiring as much as a single OS instance per virtual user, which would then be 1500 load generator instances. Without knowing your virtual user types and the precise resource fingerprint of your virtual users the answer becomes almost impossible to answer correctly. Take advantage of your primary foundation skills to profile the resource usage of 1 user, then 5 users, then 10 users, then 50 users on a load generator and project out that curve. The curve is not linear and is impacted by the number of users as multiple mdrv instances may need to be kicked off to support a particular user load.
Could you please tell me the required configuration of each system in the architecture (vugen, controller, analyser, load generator)
All Machines Quad Six Core Xeons with 96 Gig of RAM Raid 5 with 12TB in the array (8+1) on SAS plus fiber channel link Quad Intelligent Network Adapter, 10/100/1000/10000 copper and fiber links for each. Use one link for test control and the others for test execution Yep, that should do it
James could you tell me the system requirements seperately for each
Could you download and read the requirements and installation guide
Thanks james sry fo the trouble. There was an discussion like the controller , load generator, vugen seperate server thats y asked you is there any specific req
