I have recorded a Thick client application script uisng LR 12.0...
Sreedhar Gopagani
I have recorded a Thick client application script uisng LR 12.0 Web(HTTP/HTML) protocol and script recorded with out any issue. After few days I have tried again to record the same scenario, in recording pane events are showing but nothing is recorded in the script. Can any one help me in finding what are recording options I have used in the recorded script,in which file I can see the recording options I have used previously. I have successfully recorded script with me. Thanks in Advance.
1. open recording options under Record Tab - Click on Mapping and Filtering - under that change "Capture level" Socket level and WinINet level data and then try for recording. 2. Still issue didn't resolve means, kept the same settings as option 1 and go to browser proxy settings - select Connections tab - under that click on LAN settings - uncheck all check boxes and try. Try these 2 options it will work.
Thanks for the suggestions. The above mentioned 2 suggestions didn't solved my issue. Is there any way to find the recording options used in the recorded script?
Update your LR application to 12.02 and try same settings which I mentioned above, because I am using LR 12.02 and faced same issue I tried same settings its work for me. try with chrome and firefox browser too.
