In correlation what will i do if my left boundary & right boundary...
Abu Jafor Ansary
In correlation what will i do if my left boundary & right boundary are also dynamic?
Please use DIG in your function. For more details visit qainsights.com via Google search
many ways.. If the dynamic value number count is constant use wild cards of web reg save param attributes. and the count of LB and RB is dynamic, you can try regular expression function / using stringtokenizer you can capture the required data.
Use DIG function or use before line as a LB after line as a RB
Use LB/DIG,RB/DIG and place special characters for changing boundaries....
