I've recorded one video using multi protocol...
  • Thread starter Santosh Kumar Gattu
Santosh Kumar Gattu
I've recorded one video using multi protocol (Real + WebHttp/HTML). While replying, I'm not able to get any flash content in Runtime Viewer... Tool Used: HP Loadrunner 11.0. Any work around on this? Thanks in Advance..
First of all, you need to answer that what channel is used to communicate over the network between client and server. second, I guess as your expecting the flash content, then the channel should be RTMP over TCP OR RTMP over UDP. I guess LR.11 supports RTMP over UDP. Therefore, once you clear with this, then also I doubt that Run Time Viewer will be able to fetch the response of Flex/Flash content. You need to investigate the AMF /RTMP calls through the tree view response during replay.... Hope this info would be helpful for you.
"I'm not able to get any flash content in Runtime Viewer." It's not a real browser. It will not support the browser plug in to play flash media. Flash is simply a file type. So long as your file downloads in less time than the play length of the file then you are going to be OK. What the flash player does is simply open a file and begin playing without respect to whether the file has completed downloading or not, so you can still have a download ongoing while the file is playing.
