Please help here!
G
Gaurav Chawla
Please help here!
safe_image.php
The tool used is loadrunner 11.00 AUT is Oracle E-Buissness Suite Protocols used :- Oracle NCA, Web i have ensured that :- the necessary correlations are performed.
Don't know the solution... It's always good to use latest version of LR, you may try it in LR12..
I dont think the error is "WRONG_NCA_VERSION_USED_WHILE_CONFIGURATOR_CALL_PERFORMED" from the logs, it appeared as a parameter that was substituted. I could see the actual error as "Error: nca_popup_message_press("Note","OK") failed, Window or object is not displayed".. Also, I observed that NCAJservSessionID is not replaced. Looks like you have applied your own correlation to that value. This is one common mistake that many people do. You have to use the NCAJservsessioID which is present in the script. This is a reference to Relative url which you can find in the default.cfg file of the script folder. I suggest you to remove your correlation done for the session ID and use NCAJServSessionID which is created by LR. After changing the correlation, disable heartbeat in RTS of the script. If you still face issues after that, invoke your HP Support contract. PS: LR 11 has reached end of support in Feb. You better upgrade if you want to contact HP Support.
Thanks Sudheer ! Have corrected the JServsession id correlation. But now the script gets stuck in between, have modified my question on the above link and attached new logs. Request your kind attention :)
Is it possible for you to send me the complete script folder? It should be replayed with full extended logs..
Turns out to be an unsupported environment issue had to disable dep via regedit, also migration from 11.00 to 11.52 proved fruitful in many aspects
