Trying to run an ODBC script on controller using one load...
N
Naitik Gupta
Trying to run an ODBC script on controller using one load generator and it fails with below error(runs fine on vugen on the same load generator) "SQLDriverConnect", return-code=-1, native-error-code=160, SQLState=IM003, SQLError=Specified driver could not be loaded due to system error 126: The specified module could not be found. (Teradata, C:\Program Files (x86)\Teradata\Client\15.00\ODBC Driver for Teradata\Lib\tdata32.dll)." Any help is appreciated
" SQLError=Specified driver could not be loaded due to system error 126: The specified module could not be found ....." What is your hypothesis? Seems very obvious based upon the error
Try to upload tat tdata32.DLL file to your script just right click on extra files and upload tat DLL file to script. So every time LG will take DLL file from script relative path I believe it will help u
That file is part of the terradata odbc driver. Not appropriate for extra files
ODBC driver is missing on your LG machine. Install the driver
please add tat driver .DLL file in ur LG machine by using below steps and see Choose the Administrative Tools icon from the Windows Control Panel. Choose the Data Sources shortcut. In the ODBC Data Source Administrator dialog box, click Add, then select the driver you want from the Installed ODBC Drivers list and choose OK. Try this method hopefully it will help u
